    $2,499.99
    • FEATURES
      • Virtually silent operation
    • SPECS
      • Power Accuracy: +/- 1%
      • Maximum Power Output: 2200W
    • SETUP
    RECOMMENDED ADD-ONS
    Wahoo SPEEDPLAY ZERO dual-sided stainless pedals.
    SPEEDPLAY ZERO Pedals
    $199.99
    Stainless steel dual-sided bike pedal and cleat system offer a customized fit for peak power transfer.
    Wahoo Fitness Standing Desk Extended
    KICKR DESK
    $199.99
    Sturdy and slip-resistant surface keeps everything in place and within reach for your ride.
    Wahoo KICKR Trainer FloorMat
    KICKR MAT
    $79.99
    TRACKR HEART RATE
    $89.99
    The Wahoo TRACKR HEART RATE monitor is accurate, reliable, comfortable, and connected, perfect for enhancing athletic performance.
    True Fit
    Guided by an intuitive set-up app, KICKR BIKE SHIFT's 5-point adjustment system lets you easily adjust frame, setback and reach dimensions to optimize overall bike fit for comfort and performance.
    KICKR BIKE SHIFT Features
    Real-time response
    KICKR BIKE SHIFT features a brake and belt drivetrain system that delivers responsive resistance to grade and power changes.
    Reality Shift
    True fit
    Your ride. Inside.
    MAX GRADE SIMULATION
    10% 12% 16% 20%
    MIN GRADE SIMULATION
    10% 12% 15% 20%
    MAX POWER (WATTS)
    1500w 1800w 2200w 2500w
    Real-Time Response
    KICKR BIKE SHIFT's innovative brake and belt drivetrain system delivers lightning fast resistance response to grade and power changes.
    Five Points of Adjustable Fit
    Adjust the fit of your smart bike to match your outdoor bike's geometry across 5 points - stack, reach, setback, saddle height, and frame height.
    Programmable Virtual Shifting
    Customize the KICKR BIKE SHIFT controls to match shifters from the leading manufacturers - SRAM, Shimano, and Campagnolo.
    Programmable Gearing
    No Limits training with Wahoo X
    KICKR BIKE Shift Specs
    Tech Specs
    • Product Weight: 79 lb / 36 kg
    • Drivetrain: Belt Drive
    • Resistance Type: Electronic Brake
    • Power Accuracy: +/-1%
    • Crank Arm Lengths (mm): 165, 167.5, 170, 172.5, and 175
    • Rider Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
    What's in the box?
    • KICKR BIKE SHIFT smart bike
    • AC Power Adapter
    • Handlebar Assembly
    • Does not include pedals
    SUPPORTED DEVICES
    • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
    • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
