RPM Cycling Sensor Bundle
    $69.99
    All you need for cycling data, all together at once! The Wahoo RPM Speed and Cadence sensors are both a sleek, wireless, and magnet-less solution. Each mounts easily to your bike and the Bluetooth Smart and ANT+ duel band technology allows you to connect and display data on both smartphone and bike computers.
    Purchase with pre-tax dollars and get tax-free reimbursements.
    Dual Band Technology
    Wireless Connection
    Sleek, Lightweight Design
    It only weighs 7 grams!
    Cadence Measurement
    Provides accurate cadence data during your ride
    Peloton iOS Compatibility
    RPM Cadence easily pairs with the Peloton Digital iOS App via Bluetooth to get real time cadence data during your spin workouts.
    Two Bike Mount Options
    The RPM Cadence sensor has two bike mount options: (1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
    Shoe Mount Option
    The RPM can be worn on your shoe for spin classes or use with multiple bikes
    Hub Mount
    RPM Speed mounts on most front wheel hubs with a secure silicon casing.
    Visible Connection
    Two LED lights show the sensor's device connection (blue) and cadence detection (red)
    Replaceable Battery
    No charging required! Operates on a coin cell battery for up to 1 years.
    Universal Fit
    RPM cadence sensor will fit with most bikes and frame sizes
    What's Included?
    For RPM Cadence
    • RPM Cadence sensor CR 2032 Battery (installed)
    • Rubber Mounting Option
    • Zipties
    • Shoe Mount Option
    • 3M double sided tape
    • Quick Start Guide
    For RPM Speed
    • RPM Speed sensor CR 2032 Battery (installed)
    • Hub Mounting Option
    • Quick Start Guide
    Tech Specs
    For both RPM Cadence and RPM Speed
    • Part Number: WFRPMC
    • Dimensions (LxWxH): 1.25" x.75" x 1"
    • Weight: 7 grams (without mount)
    • Battery: CR2032
    • Wireless Signal Strength: Up to 10 feet
    • *Note: Speed Sensor is NOT compatible with spin bikes
