Smart Bike Trainers
The ultimate indoor cycling experience
For All the Ways You Ride
Our KICKR line of indoor bike trainers offer something for every level of cyclist to achieve their goals. Experience the most realistic ride feel and accurate, responsive resistance whether doing structured workouts, riding virtual worlds or re-riding routes on your gps bike computer.
KICKRMOVE
$1,349.99
Shop Now
$1,049.99
Shop Now
KICKRCORE
$534.99
Shop Now
KICKRROLLR
$699.99
Shop Now
KICKRSNAP
$199.99 $299.99
Shop Now
Controlled resistance
KICKR smart trainers' heavyweight flywheels are engineered to provide riders with the precise inertia needed to recreate an outdoor ride feel while training indoors. When connected to your smartphone, tablet, computer or GPS bike computer, KICKR automatically sets and adjusts your resistance based on the software or route.
Unbeatable connectivity
Compatible with the largest array of third party apps and devices, KICKR bike trainers allow you to train your way with up to 3 Bluetooth connections simultaneously, WiFi and ANT+, ANT+ FE-C.
Easy to store away
Portable and convenient, KICKR smart bike trainers are simple to fold up and store in your home when you are not training, making it easy to transition between indoor and outdoor cycling. KICKR ROLLR's foldable arms and KICKR's carry handle make portability a breeze.
Easy to Store
The Ultimate Indoor Cycling Ecosystem
Level up your setup with a complete ecosystem of accessories and devices for the most immersive indoor experience - simulating everything from routes and headwinds to grade ascents and descents. KICKR smart bike trainers, excluding ROLLR, are the only bike trainers on the market compatible with KICKR CLIMB, allowing you to take your climbing to new heights.
Starting at
$534.99
Wheel-Off
Replace your bike's rear wheel and connect the bike trainer directly to the drivetrain. Direct-drive trainers offer accurate power measurement and a more realistic road feel by eliminating tire slippage. They are known for high accuracy and durability.
Convenience
Power accuracy
Virtually Silent
Road Feel
$1,349.99
Shop KICKR MOVE
$1,049.99
Shop KICKR
$534.99
Shop KICKR CORE
Wheel-on
Wheel-on trainers offer the simplest way to mount an outdoor bike onto the trainer, making it quick and convenient to transition your bike between indoors and outdoors. The rear wheel stays on the bike and the roller provides resistance.
Convenience
Power accuracy
Virtually Silent
Road Feel
$199.99 $299.99
Shop KICKR SNAP
Breeze through setup and customize it all like magic.
    Unbox, plug, tap, then workout. The Wahoo app walks you through getting started step by step.
    With a Wahoo X Membership, turn any past activity into a custom route, or upload your dream ride or upcoming race to recon indoors on your KICKR smart trainer or bike.
    With a Wahoo X Membership, execute structured cycling workouts in Wahoo app from Wahoo SYSTM's extensive workout library.
    KICKRMOVE
    Comfort in Motion.
    • Wireless Technology: WiFi, BLUETOOTH, and ANT+®
    • Accuracy: ± 1%
    • Wireless Updates: Automatic when paired to WiFi Network
    • Max Power Wattage: 2200 Watts
    • Simulated Gradient: +20% / -10%
    • Flywheel Weight: 16 lb 7.3 kg
    • Footprint (L x W): 27” x 34” x 26.6” 68.6 x 88 x 67.6 cm
    • Total Weight: 64 lb 29 kg
    • Wheel Size: 700c RD / 650b MTB / 29” MTB
    • Axle: 130 and 135mm quick release, 12x142mm, and 12x148mm
    • Cassette**:
      11 Speed with 11-28 ratio included.
      Compatible with 8, 9, 10 & 12 Speed.
    • Zwift Cog & Click Compatible
    • Check Bike Frame Compatibility
    • Check Drive Train Compatibility
    Legendary Performance. Revolutionary New Price.
    • Accuracy: ± 1%
    • Footprint (L x W): 21" x 28" 54 cm x 71 cm
    • Total Weight: 47 lb 21 kg
    • Wheel Size: 24", 650c, 700c, 26", 27.5", 29"
    • Cassette**:
      Compatible with 8, 9, 10, 11 & 12 Speed.
    KICKRCORE
    All the Essentials. Unbeatable Value.
    • Wireless Technology: BLUETOOTH, ANT+®, and ANT+ FE-C
    • Accuracy: ± 2%
    • Wireless Updates: Yes, via Wahoo App
    • Max Power Wattage: 1800 Watts
    • Simulated Gradient: +16% / -10%
    • Flywheel Weight: 12 lb 5.4 kg
    • Footprint (L x W): 20" x 23" 50 cm x 58 cm
    • Total Weight: 40 lb 18 kg
    • Cassette**:
      11 speed, 12 speed or no cassette versions available.
    KICKRROLLR
    The Fastest Way To Get Training.
    • Accuracy: Dependent on your power meter
    • Metrics:
      Speed and Distance
      (plus Power and Cadence with power meter)*
    • Max Power Wattage: 1500 Watts
    • Simulated Gradient: +10% / -10%
    • Flywheel Weight: 10.5 lb 4.7 kg
    • Footprint (L x W): 39.9” x 11.1” 101 cm x 28 cm
    • Total Weight: 50 lb 22.6 kg
    • Wheel Size: 700c Road
    KICKRSNAP
    Get Riding in a SNAP.
    • Accuracy: ± 3%
    • Metrics: Speed, Distance, Power
    • Simulated Gradient: +12% / 0%
    • Footprint (L x W): 29" x 26" 74 cm x 66 cm
    • Total Weight: 38 lb 17 kg
    • Wheel Size: 650c, 700c, 26", 27.5", 29"
    • Axle:
      (12x142mm adapter sold separately)
    * Power Accuracy + Metrics reflect the POWRLINK ZERO Advanced Power Pedal System Dual and Single Sided. KICKR ROLLR power accuracy will reflect the power meter that’s connected to the device.
    ** KICKR + KICKR CORE are compatible with SRAM 12speed and Campagnolo with purchase of separate freehub adapters
    KICKR ROLLR is also available with POWRLINK ZERO Single Sided Power Pedal
    KICKR CORE ZWIFT ONE is available with a pre-installed Zwift Cog and Click
    FAQ
    Bike Compatibility
    KICKR trainers are compatible with most modern road, mountain, and gravel bikes. Compatibility depends on your bike's drivetrain and axle configuration. Check our online compatibility guide or contact support with your bike's details for a definitive answer.
    KICKR trainers include adapters for common axle standards. Some bikes with unique configurations may need additional adapters. Consult our compatibility guide or support team to determine if you need extra adapters for your bike.
    Cassette Compatibility
    KICKR COREs are offered with a variety of cassettes. KICKR and KICKR MOVE are offered with 11 speed cassettes. KICKR direct drive trainers are compatible with 8-12 speed cassettes from major manufacturers using the Shimano HG freehub standard. Some 12-speed systems may require a specific freehub body. Check product specifications for details.
    Usually, yes. If your cassette is compatible with the KICKR's freehub body, you can transfer it. Many users prefer a dedicated cassette for their KICKR to avoid frequent swapping.
    Zwift Compatibility
    Yes, all KICKR trainers work with Zwift, providing power data, resistance control, and gradient simulation.
    Do KICKR trainers support Zwift's virtual shifting?
    KICKR v6, KICKR MOVE, and KICKR CORE are compatible with Zwift virtual shifting. They can be purchased with a Zwift Cog and Click installed, or the Zwift Click and Cog Upgrade Kit can be purchased separately.
    General Product Information
    KICKR models differ in power output, accuracy, connectivity options (e.g., Wi-Fi, Direct Connect), and virtual cycling feature compatibility. Higher-end models typically offer better performance, more features, and wider compatibility with bikes and cycling platforms.
    Wi-Fi and Direct Connect are available on KICKR v6 and KICKR MOVE models. Check specific model specifications or contact support for feature confirmation.
    Setup and Accessories
    You'll need the KICKR trainer, a compatible bike, matching cassette (if not included), any necessary adapters, basic tools for cassette installation, and a device for the Wahoo app setup. Consult the user manual for detailed instructions.
    KICKR trainers include adapters for most common axle standards. Bikes with unique configurations may need additional adapters. Check our compatibility guide or contact support if unsure about your bike's requirements.
    Wheel-on trainers (like KICKR ROLLR) use your bike's rear wheel against a resistance roller. They're more affordable and easier to set up. Direct drive trainers (like KICKR CORE and KICKR) attach directly to your bike without the rear wheel. They offer a more realistic feel, quieter operation, and typically more accurate power measurements.
    Choose wheel-on for budget-friendliness and easy switching between indoor/outdoor riding. Opt for direct drive if you want the most realistic feel, quietest operation, and highest accuracy. Consider your budget, space, and training goals when deciding.
    While not required, a trainer-specific tire is recommended for wheel-on KICKR models. These tires better withstand the heat and friction of indoor training, reducing wear and noise.
    Yes, most KICKR trainers accommodate various bike types with the right adapters. Check the specific model's compatibility information and included or available adapters for your bike type.
    Direct drive KICKR trainers generally offer higher power measurement accuracy than wheel-on models, as they eliminate variables like tire pressure and roller slippage. Both types provide reliable data for effective training.
    Calibration frequency varies. Wheel-on KICKR trainers should be manually calibrated before each ride. Current direct drive models offer auto-calibration. Follow the Wahoo app instructions for your specific model.
    We're here to help
    Get help choosing a smart trainer or designing a whole pain cave when you shop one on one with a Wahoo export. Call, chat, or schedule a time to connect.
