TRACKR Heart Rate Replacement Strap
    $34.99
    This extra long heart rate strap is compatible with the TRACKR HEART RATE MONITOR. The soft, elastic material minimizes the chance of chafing and is easily hand washable. The two-snap connection is simple to get on and off, and the straps adjustable length gives you a secure, reliable fit.
    Note: This item is not compatible with older Wahoo Fitness heart rate monitors.
    What's Included?
    • 1 TRACKR Replacement Heart Rate Strap
    Tech Specs
    • Strap Weight: 1.13 oz 0.07lb
    • Sweat Proof: Yes (handwash only)
    • Strap Length:
      Standard: Adjustable from 26" - 35" 67 cm - 88 cm
      XL: Adjustable from 29" to 40" 72 - 102 cm
    • Note: This item cannot be returned or exchanged unless defective. Heart rate sensor pod not included.
