KICKR BIKE PRO redefines indoor cycling. With next-gen shifter controls, premium touchpoints, and unmatched ride realism, it delivers the most immersive indoor training experience yet. Built for riders who demand peak performance and complete control, this is the evolution of indoor riding.
ANT+, ANT+ FE-C
Belt Drive
Drivetrain
How KICKR BIKE PRO compares to the bikes and trainers around it, what Race Mode does, and how the fit adjusts to you.
The KICKR BIKE PRO stock handlebars are compatible with most aftermarket clip-on/bolt-on aerobars, offering a 31.8 mm diameter clamping surface that is 100 mm wide overall. The stock stem clamp is 40 mm wide. There is an available clamping surface from 20-50mm from the handlebar's center point on both sides.
Spares & compatible add-ons for the KICKR BIKE PRO.
California residents: See the California Proposition 65 warning.
